compare connector pane programatically
Can we comapre the connector panes of two VIs prgramatically?
(3,288 Views)
Hi Pritam,
yes it´s possible with scripting.
Mike
(3,286 Views)
Can you explain in detail?
(3,280 Views)
Accepted by pritam
Hi Pritam,
if you use the attached vi, you get information about the used pattern and which object is connected.
Hope it helps.
Mike
(3,273 Views)
Thanks Mike. But I cant find this property in my LV 8.5.1. Is it outaded? see the attachemnt to see what properties I can see.
(3,256 Views)
Hi Pritam,
no it´s not outdated. It´s a private feature. See this link.
Mike
(3,250 Views)
