computational complexity calculation for prototyping
Hi All,
I want to use labVIEW  to run some algorithms.  These algorithms will ultimately run on an embedded system so not only do I wish to examine the algorithmic performance but also a measure of the computational complexity
What is the best way to measure computational complexity? Is it the number of floating point operations?  Does labview have an application that measures the number of floating point operations?
Sean
(3,244 Views)
This whitepaper may be of help: https://www.ni.com/en/shop/labview/estimating-code-complexity-in-labview.html
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
(3,237 Views)
Thanks .aCe.
Unfortunately, I am not really interested in SLOC as we are using large matrices and transforms.
A metric such as the number of floating point or mathematical operations might be helpful.
(3,227 Views)
Hi Sean J,
The tools in LabVIEW under Tools>Profile might help you.
(3,195 Views)
