04-20-2010 03:58 PM
It has been a while, but yes, I believe so.
DaveT
04-20-2010 04:15 PM
 rolfk
			rolfk
			04-21-2010 01:04 AM
I haven't played with this yet but I guess the problem Dave is having, is that the conditional symbols are in fact a project setting. Once the VI library is moved over into an executable and run from there as plugin those conditional symbols do not exist anymore since there is no project anymore.
Why this worked in 8.2 and 8.5 I can only guess but likely the source distribution did not include everything then but only the code based on any currently set conditional symbols. So creating a source distribution should really have an option that allows selecting to include everything or only the code based on any current project settings (and the first option should be default).
04-28-2010 03:11 PM
Rolf,
The thing that is weird to me is the default on the conditional disable is to NOT use the DAQmx VIs. And it works fine when you run the VI by itself.
Everyone:
After a lengthy discussion with the LabVIEW team I have filed CAR 223572 to R & D on the issue. As usual, I cannot give a timeline on any solution.
Hopefully they will get to the bottom of this.
 Ben
			Ben
			04-29-2010 09:13 AM
I am late to this discusion but will share what I know.
THere was a bug in the Source Distribution in early version of LV 8 that prevented any code in a diagram disable from being included in the distribution. This bug prevented us from using the surce distribution to package up code for another developer since there was stuff missing.
I beilve that bug has been fixed.
So i wonder if you hade been taking advantage of the bug and now that it is fixed you have trouble.
LVOOP dynamic dispatching is wht I have turned to recently for challenges like this since they handle the dynamic stuff well.
Ben
04-29-2010 04:18 PM
Ben,
It does indeed sound like we were taking advantage of the bug in earlier versions of LabVIEW. Too bad you managed to get that one fixed!!! In any case, I think we have defined another use case, and from the sounds of it, this thread has managed to clear up the conflicting requirements/desires/behaviors. Perhaps a future version of LV will allow us to build distributions the way we had wanted to as well as the way one currently can.
DaveT
05-26-2010 11:06 AM
 cgibson
			cgibson
			07-13-2010 09:55 AM
 Tanya_V
			Tanya_V
			07-14-2010 12:15 PM
Hi cgibson,
Unfortunately using the conditional disables to make plug-ins is not going to be an option. To make sure that your code works, you will have to include all necessary libraries in the build from the start.
Take care!
 cgibson
			cgibson
			07-26-2010 03:11 PM
I have attached a simple example in LV 8.6 code to demonstrate this problem.
There are two project files and two deliverables.
The application calls a function in the source distribution to get a number and a string. For the custom symbol CUSTOMER == A, the number is the increment of the input number and the string is Customer A. For CUSTOMER == B, the number is the square root and the string is Customer B.
When you run the application from the EXE, it is impossible to run the Customer B case. If you run the application from source, you can set the custom symbol and make it work.
The main application works by first browsing with the path control to the source distribution LLB, and then pressing the Go button.
