06-30-2008 07:37 PM
07-02-2008
08:33 AM
- last edited on
09-21-2026
04:56 PM
by
Content Cleaner
07-02-2008 09:56 AM
07-07-2008
04:13 PM
- last edited on
09-21-2026
04:56 PM
by
Content Cleaner
Hi Exo,
"You can only use DataSocket as a client on Linux, Solaris and Macintosh. This means that from a non-Windows machine you can publish to and read from a DataSocket Server, but the server itself must be running on a Windows machine. The DataSocket Server application is built on Windows-based ActiveX technology and so is only available for Windows environments." This is from KnowledgeBase 29A9RA8V.
In the LabVIEW Example Finder >> Communicating with External Applications >> OLE for Process Control (OPC) >> open the Browse to OPC Item example. The example will build the URL to the OPC server item if it is available on the network. You can also see How Do I Use OPC in LabVIEW? I hope this helps.
