constrainte
hello,
i have trouble with a simple operation : min value
i works if user click on command but not with value initializing numeric, is it a question of block ordering ?
i don't see what it doesn't consider min constrainte on zero value
Best regards
tinnitus
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
(3,268 Views)
What are you trying to do here. Do you want the numeric to coerce the value to three if it is less than three?
Tim
GHSP
(3,252 Views)
yes
(3,242 Views)
Accepted by tinnitus
what you see is expected behaviour.
The constraints set are only for user behaviour, if you update a control in code you should test for limits yourself.
Ton
My LabVIEW Ideas
(3,241 Views)
Here is how you do it.
Message Edited by aeastet on 04-28-2010 09:46 AM
Tim
GHSP
(3,225 Views)
