controller connection
I have bought a stepper motor(http://www.newmarksystems.com/linear-positioners/nls4-series/)
and a controller (http://www.newmarksystems.com/motion-controllers/nsc-a1/).
How can I connect my controller to the labview???
I used find instrumentation driver in the software bt it cannot find controller driver. The stepper motor's company just gave me a .dll file and they said you can connect it to lsbview.
I would be gratefull if anyone can answer my question.
Hamed
Message 1 of 15
(6,296 Views)
Their example programs provide LabVIEW examples. Did you look at them?
Message 2 of 15
(6,277 Views)
Thank you for your answer.
I don't know what is this .dll file for?
where is theses labview examples that you are talking about?
Message 3 of 15
(6,267 Views)
Right on the page for which you provided the link there is a link called "Libraries, Sample Code". If you download that file and uncompress it, you will find a "Sample Source Code" folder. In there are numerous examples. For instance, the "Serial" folder contains examples on communicating with the controller over a serial port, and has LabVIEW examples. The "USB" folder contains examples on communicating over a USB port. That example uses the DLL.
Message 4 of 15
(6,262 Views)
I 'm sorry, I made a mistake.
The file extension is     .llb     not    .dll
what is this file for?
do I need the .dll file?
Message 5 of 15
(6,238 Views)
Accepted by hamed71200
An .llb file is a library of LabVIEW vi's "zipped up" into a single file.  LabVIEW can open it directly.
No you don't need a .dll.  You were the one who brought that up.
Message 6 of 15
(6,231 Views)
Thank you a lot for your attention and I am sorry, that I am bothering you again.
If I understand you correctly, for connecting stepper motor and its controller to labVIEW, the .llb file is enough and we don't need the .DLL file.
Message 7 of 15
(6,229 Views)
That's what the 2nd line of my message said.
Message 8 of 15
(6,222 Views)
Ok, I got it.
I want to program the stepper motor to move for specific distance with spercific speed and logging the position in every second.
Can you tell me waht should I do? I mean that can you explain me the process step by step?
Thank you
Message 9 of 15
(6,200 Views)
http://www.youtube.com/watch?v=1KT98-7B2E8
Should I do the same thing as this video?
I tried to do this, but I the labview cannot find the driver for controller.
Message 10 of 15
(6,188 Views)
