Showing results forĀ
Search instead forĀ
Did you mean:Ā
convert 2d array into 1D array with cluster of 3 elements
hi every one
Is there an easy way to convert a 2D array of clusters (3 elements) to a 1D array of cluster of 3 elements? I need to do this in order to store my large data to be compatible as this data type . as the attached vi , convert "3d point" that is 2d array to 1d array of cluster of 3 elements as "vertex array"
(6,066 Views)
Reshape array?
Ben
(6,061 Views)
There is nothing attached. Yes, reshape to 1D with a size of the product of the dimensions is probably the right thing here.
(6,056 Views)
i used the reshape array as attached , but the result is 1D array of cluster with 1 element , I need a 1D array of cluster with 3 elements. any idea please??
(6,046 Views)
Accepted by topic author ssara
Your input is a 2D array with three columns (no clusters!), so all you need is the following:
(6,036 Views)
thank u Smiley Happy
(6,030 Views)
