convert a 7.1 to 7.0
Hi!
Is there anyone that can convert these  file from Labview 7.1 to 7.0 ? As I see it there is no other way of doing it, or is there ?
Thanks for your help
(2,694 Views)
It will not translate to 7.0 without breaking one of its VIs.
The VI "MB Serial Slave Demon.vi" uses a timed loop that was not available in 7.0.
If you can build your own timed loop then it looks like it stands a chance of working. Good Luck!
Message Edited by Warren Massey on 03-21-200605:19 AM
(2,678 Views)
This Timed Loop can be simply replaced with a (less effective) Wait Until Next ms Multiple to which Period must be wired.
Paolo
Paolo
(2,672 Views)
