convert binary string into binary array
thank you altenbach for support Smiley Wink
Message 11 of 12
(3,119 Views)
Hey guys,
National Instruments has been working with Test System Strategies Incorporated (TSSI), an NI Alliance Partner to develop a new pattern conversion tool called the TSSI TD-Scan for National Instruments to enable engineers to import WGL and STIL vector formats into PXI.   The software coverts digital test vectors from either WGL or STIL to work directly with NI 654x and NI 655x digital devices.
The software tool is available from TSSI and is included as a 30-day evaluation package with NI high-speed digital I/O PXI hardware.  You can also request an evaluation version at the link above.
To learn more about the tool, check out the following whitepaper and webcast:
Using TD-Scan with National Instruments High Speed Digital Devices (NI 654x and 655x)
Importing WGL/STIL files with the TSSI TD-Scan for National Instruments (webcast)
Scott Savage
Semiconductor Market Development Manager - Semiconductor Test
Message 12 of 12
(2,529 Views)
