counter program? Like a ticker
Since you are a newbie to the forum, please know about this.
You can at anytime unmark a solution which you marked previously. Just click on options menu located at the top right corner of the post where you marked solution and select "unmark this solution" and then you choose the post that best solves your problem and mark it as solution.
All kind of doubts are welcome. Smiley Happy
Message 11 of 12
(447 Views)
Again (because I seem to have been ignored before), do you have a reason to not simply use a numeric with it's increment and decrement buttons?
Tim Elsey
Certified LabVIEW Architect
Message 12 of 12
(445 Views)
