create a circle using only the radius and without using sine and cosine
I have tried to complete this but I have no idea where I am going wrong, the weird thing is that after the number 50, I think, it creates a half circle but it starts at number 8 of the Y.
Message 1 of 12
(676 Views)
I can't open your code unless you do a "save for previous" (2020 or below).
If complex data is allowed, all you probably needs is the following:
Message 2 of 12
(656 Views)
or alternatively something like this, maybe:
Message 3 of 12
(645 Views)
I love you very much, I started to base myself on your code to make it in the form of a block diagram since I was asked to do it that way and not with code or something else that makes it much easier. I am already making progress, you have helped me a lot.
but as you can see I'm still missing
Message 4 of 12
(630 Views)
You still did not do a "save for previous", But try something like this...
Message 5 of 12
(622 Views)
Try this way:
Message 6 of 12
(617 Views)
where that orange/cafe array is located/created
Message 7 of 12
(606 Views)
It is an array of points where a point is a cluster of two DBLs, one for x and one for y.
Message 8 of 12
(599 Views)
Technically, you can avoid this if you compute the upper and lower halves of the circle in a single for loop, something like this:
Message 9 of 12
(576 Views)
I would even do a loop free solution.
I still strongly prefer my first suggestion because the circle is guaranteed to close and the points are evenly distributed around the circumference.
Attached are both versions.
Message 10 of 12
(498 Views)
