create sub vi programmatically
I am currently working on library development for multiple instruments. It is based on event driven producer consumer and queued message handler.
Now I am trying to create library programmatically using vi scripting.
Things are going smoothly but I am stuck at one point.....
I have selected a portion of the code through scripting. Now I want to create a sub vi from this. So the question is .....
Can I  create a subvi programmatically through scripting??
CLD Using LabVIEW since 2013
(3,659 Views)
Accepted by topic author kartiknattar
Hi Kartik, will this work for you?
(3,611 Views)
<nevermind>
Jim
(3,599 Views)
I cannot see that option...
And your invoke node looks different.. How so??
(3,554 Views)
I just needed to enable private class..
(3,535 Views)
