curve fitting function doesnt work
no i never thought about cheating. i made it jpg, because jpg has smaller size then bmp.
i just didnt know the rules, should i share it only as vi?
Message 11 of 15
(976 Views)
you are right, i thought, labview would give a small error window,
i made size of x and y arrays same, it works now.
thanks.
Message 12 of 15
(973 Views)
I have automatic error handling turned off, so I am not sure.  It may not work for VIs like the General Polynomial Fit.vi which do not have the standard error cluster.
The help files on error handling are not clear on whether automatic error handling works on such VIs.
Lynn
Message 13 of 15
(966 Views)
Why would you think that changing the file extension would make the file smaller? That makes absolutely no sense! You need to convert the image using software.
(open your image in notepad and you'll see immediately that it is not a jpeg. Just because modern browsers are somewhat idiot proof, automatically detect the filetype and display the image correctly even if the extension is not right, does not mean what you are doing is sane.)
Message 14 of 15
(949 Views)
i just tried, u are right, it doesnt change size.
i dont know why it stayed in my mind like that.
thank altenbach.
Message 15 of 15
(929 Views)
