dBA Messung mit Soundkarte/ dBA measuring with a sound card
The example from MarianMO was somewhat confusing for your need. Even if it is step in the correct direction. Take a look at my half done mod of your program. You have to add the scaling functions. Also reading the sound buffer once every second should be more than good enough. Read this also http://zone.ni.com/devzone/cda/tut/p/id/4278
By the way running a Labview program with the continuous run button is a NO CAN'T DO. This function is for debugging only. Use a while loop like I did
I think this should work but I have not testet it;)
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 11 of 26
(2,265 Views)
Bonjour Coq Rouge,
thanks for your clarification, but I am a bit confused about the constant at the while-loop:
Message Edited by MarianMO on 11-03-2009 01:52 PM
Marian Vorderer
Message 12 of 26
(2,259 Views)
My example was just meant as a push in the correct direction, or a casting frame for further programming. I am sure the honourable Alesis will be able to work on the minor details;)
Message Edited by Coq Rouge on 11-03-2009 02:00 PM
Message 13 of 26
(2,250 Views)
First: Thank you very much to both of you!!!
I've looked at the example. But unfortunately it was not working.
However, I must first look what happens everything in vi.
I hope I will still get out somehow so I can finish the project Smiley Very Happy
(the dB(A) measuring is the last part from the whole vi!!!)
Best regards
Alesis
Message 14 of 26
(2,237 Views)
By the way: National Instruments Germany offers special student discounts for their training courses, if you are interested, take a look to:
http://digital.ni.com/worldwide/germany.nsf/web/all/12FEA617410A39418625745600480CA7?OpenDocument&no...
Marian Vorderer
Message 15 of 26
(2,233 Views)
My example had a few faults. Then you use the "SI Read.vi" the number of samples is equal to buffer/2. I did not know that. The rest is up to you.
Message 16 of 26
(2,229 Views)
Smiley Very Happy Tank you MarianMO!!!
That's great...
But my time is running!
This is my diploma thesis and my first project with LabVIEW. I must therefore deal with labview and acoustic.
Since both new to me, i simply have difficulties!
But as I said: I hope i can solve this dB(A)-problem and come to an end Smiley Happy
Maybe with your help... Smiley Wink
Best regards
Alesis
--> thank you Coq Rouge for the new vi!!! I take a look at the vi and then report back!!!
Message Edited by Alesis on 11-03-2009 08:19 AM
Message 17 of 26
(2,228 Views)
Hello again,
I get the dBA value, if I add up the rated spectrum over the frequency  and that is in ever-smaller increments over an integration ...
Can somebody help me to realize that in my vi?!
Sorry but my LabVIEW knowledge is not enough, unfortunately!
Maybe if i see an example, all is clear. But without your help i think i can't realize it...
Thank you all
Alesis
LabVIEW Vers. 8.6
Message 18 of 26
(2,182 Views)
I looked at your(my) VI ;). I will recommend that you do not use any window function. Also if you want things correct you must use the magnitude(peak) option. I do not quite understand what your trouble are now. Can you give a better explanation.
Message 19 of 26
(2,178 Views)
Also i did not see this one because I do not use Express VIs. But it is good example of a typical express VI trap. Bottom line do not use them. They actually makes a beginner struggle more. Well anyway, you must use the Build Waveform (Analog Waveform) Function. Owning Palette: Analog Waveform VIs and Function. So you get the correct dt into the FFT Express VI. Why did you change the setting that was working correct whit standard VIs?
Also a tip. Then you are programming you MUST keep attention to details. You can not just toss in some functions and hope every thing is correct. Every time you use a filter or spectrum function you must provide some information about the sample rate or dt(1/Fs)
Message 20 of 26
(2,171 Views)
