Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
default setting
default setting
raff
Member
04-04-2007
09:46 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
How does one set up Labview so that when a new Terminal is added to the Block Diagram (Control, Indicator....) it is by default NOT an icon? To save always changing it with a right click.
Thank you.
0
Kudos
Message
1
of 2
(2,772 Views)
Reply
Re: default setting
Kenny_K
Active Participant
04-04-2007
09:54 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Go to Tools > options and click on Block Diagram in the left hand list. Then uncheck the box that says "Place front panel terminals as icons."
Kenny
1
Kudo
Message
2
of 2
(2,769 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
