delay in launching exe
i have created exe and installer in labview 11. I installed it in win 7 pc, and the software is working fine.. But initially when i starts the program, exe is taking some delay to launch.. it is taking aroung 90 seconds..
Never send a human to do a machine's job.
Message 1 of 8
(3,703 Views)
Accepted by harisiam
Sounds like a firewall issue, unplug network and compare times.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 2 of 8
(3,696 Views)
Does this happen all the time?
For instance at my PC at home, starting software esp. from the "Start" menu makes the PC doing..... something, which takes up to more than a minute. This does not happen all the time, but seems to be connected to user rights ("normal" launch vs. "Run as Admin").
Can you try launching the exe via Start menu vs. Desktop link?
Norbert
Norbert
Expert: Geometry
Message 3 of 8
(3,686 Views)
thanx for ur feedback...
firewall is disabled in the pc.. and if i disconnect also same thing is happening..
Message 4 of 8
(3,678 Views)
See in task manager whether it starts immediately or not? During developement of project it was behaving same way?
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 5 of 8
(3,674 Views)
same issue is coming..
taskmanager is showing the exe is not responding for those 90 seconds.. after that it works correctly..
Message 6 of 8
(3,672 Views)
during the developement its working normally.. i have installed in a new pc.. than its showing this issue..
Message 7 of 8
(3,667 Views)
90 sec is too much. What you are doing in VI start up?
--Ranjeet
Message 8 of 8
(3,664 Views)
