delet datalog file
I've been experimenting with the auto front panel logging facility, I have no trouble in logging data to a file in a vi and retrieving it BUT I can't seem to be able to delete the log file from the top level vi.  I get the File already open error message, but i don't seem to be able to close the file....I suspect there's a very simple answer!
Message 1 of 11
(5,110 Views)
You did not include the VI with the project file. There is nothing to open here.
Tim
GHSP
Message 2 of 11
(5,109 Views)
...here are the vi's
Message 3 of 11
(5,102 Views)
I'm interested in this function, but I can't open your VIs because I run LV8.5: was it introduced in LV2009?
Message 4 of 11
(5,088 Views)
I'm not sure when the feature was added I've just  gone straight from 6.2 to 9.... I've attached the vi's saved in 8.5 format....let me know if you can open them.
Message 5 of 11
(5,077 Views)
I can open them now, thanks a lot.
Unfortunately, after updating the file paths, I get the same error as you...
FYI, in order to log front panel data, I usually refer to this method proposed by dippi:
http://forums.ni.com/ni/board/message?board.id=170&thread.id=378313&view=by_date_ascending&page=1
Message Edited by xdaf on 01-11-2010 09:43 AM
Message 6 of 11
(5,041 Views)
Well, I'm not an expert on autolog function, so I hope I'm not writing nonsense...
But the autolog.atfinish function should log data AFTER the vi has finished executing. So... you can't delete the file DURING vi execution, because of course you're going to get a "vi already open" error.
Just an idea...
Message 7 of 11
(5,039 Views)
The second metod is very similar to what I have used in the past and works well.
re the datalog, what you say sounds sesnisble - maybe the route is therefore to call the vi with a server and then close it once used to free up the file.  I haven't tried this before so if I get time it'll be an interesting exercise...
Thanks for taking a look.
Message 8 of 11
(5,029 Views)
Here's a version using a vi server - I thought this might help with the datalog file deletion by removing the vi from memory after use....it doesn't.
Message 9 of 11
(5,023 Views)
Accepted by steveADI
...and here's my final vi's
Getdatalogs3.vi: programmatically opens simplesine.vi, sets logging on and sets the log file name, calls the vi in hidden mode, runs the vi and then closes the reflog.vi is then also called programatically which in turn calls simplesine.vi in database mode to get the log file data.
log.vi could be replaced with a vi to translate the log file data but it's already done with database function so why bother...
Message 10 of 11
(5,011 Views)
