deleting array element
Hi, muks,
If you familiar with C programming, then do it with simple function, like this:
then call DLL:
This code above executes within 30-40 ms (depends from used PC and compiler, of course) for 1500000 elemenths. There is no way do to it faster in LabVIEW. In additional, this is good exercise  - how to call external code from LabVIEW (for example, you can transfer array by handle instead of pointer, and resize array inside of the DLL, etc)
best regards,
Andrey.
Message 11 of 18
(2,417 Views)
Hi muks,
attached is the vi to remove elements without conversion to string.
Hope it helps.
Mike
Message 12 of 18
(2,406 Views)
hi mike,
             I am using labVIEW 8.0.Can you please convert the vi to 8.0.Thanx a million mikey
Message 13 of 18
(2,394 Views)
Accepted by muks
Hi muks,
here the 8.0 version.
Mike
Message 14 of 18
(2,384 Views)
Thanx a lot mikey.
Message 15 of 18
(2,379 Views)
Hello Muks,
I post this solution just because I like the indexing scheme of the MathScript node Smiley Wink. But (on my PC) this code is about 30 times slower than Mikes solution Smiley Sad.
Message Edited by UliB on 06-19-2008 09:20 AM
Message 16 of 18
(2,340 Views)
Hi ulib,
           U r right it is slow but a very intresting solution.Thanx
Message 17 of 18
(2,323 Views)
Hi mike,
              Need your help again.Can you please go through thread pleaseeeeeeeeee
Message 18 of 18
(2,300 Views)
