deployment failure of network-published shared variable library
I'm having troubles deploying a library that contains network-published shared variables.  The library is listed under 'My Computer' in my project, but the subVI that needs to access it is running under RT on a PXI Chassis.  I manually deploy the library using 'Deploy All' from the pop-up menu.  I know it has deployed because I see it listed in the Distributed System Manager under my computer in Network Items.
However, when calling the Shared Variable I get error -1950679035.  I've checked the node to make sure it is accessing the correct variable in the correct library.  Everything looks okay.
If I use this library in another project running the same scenario I have no problems.  What am I missing in deploying this library?
I'm running LV 2010 on an XP machine.
(2,524 Views)
Hi Faustina,
This KnowledgeBase article seems to talk about exactly what you are seeing.
Could you try doing what this article says and see if that resolves your problem?
http://digital.ni.com/public.nsf/allkb/749C89CAF43EE11C8625771C007A53D2
Douglas Choisnet
(2,486 Views)
