design new button in labview
hi
I wonder if is it possible to design new button in labview. in fact i dont want to change the functionality of button but i want to have new button with new graphics. for example i  a button with a special picture in its center is desired(as a uniqe object).
regards
(5,302 Views)
Hi Farashi,
select a standard button, then select menu entry Edit->Customize Control.
Change the tool to the tweezers symbol, now customize your button...
(5,300 Views)
Accepted by farashi
Here's a video how to perform this.
Here's a control that allows you to set the picture.
Here's a set of sets customized buttons  (look for the UI tool packages).
Ton
My LabVIEW Ideas
(5,286 Views)
Thanks for helpful replies from GerdW & TCPlomp . both replies helped me to create my desired bottons.
with regards
(5,272 Views)
