detect XNET single-point CAN timeout
I have implemented a CAN communication via XNET Signal Single-point settings.
I need to detect a timout on the CAN-Line if one bus-paticipant is not active any more. I found this possibility for FRAME CAN settings, but not for signal single-point.
How can I implement this timeout notification?
Thank you very much,
        Magnus
(3,771 Views)
Accepted by M.Riede
Hello Magnus,
first of all I would like to recommend the "Signal Input Single-Point Mode" in the XNET Help (first link in the XNET Read (Signal Single-Point).vi help article) for a deeper understanding of the functionality.
If you would like to implement a timeout check, you could use the "XNET Read (Signal XY).vi" function, so you get a timestamp delivered. When you poll that you can build a time difference.
Christoph
Staff Applications Engineer
Certified LabVIEW Developer (CLD), Certified LabVIEW Embedded Systems Developer (CLED)
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved
(3,728 Views)
