disable/enable the serial port
Hello All,
I am using Labview to communicate with a Microchip PIC virtual serial port. Ocassionally the serial comms is lost. To recover the connection I open Device Manager then right click the faulty comm port then select disable ( a red cross appears on the icon). Next right click the port again and select enable. The port now communicates correctly again.
Is there a way to use System Exec to drive this behavior automatically once a fault occurs or some other method to drive DM using methods and properties?
Many Thanks
Chris
(5,085 Views)
Accepted by CB
There's a commandline tool called "devcon" that offers the same functionality as device manager, just from the commandline.
(5,066 Views)
Thanks for that, I am surprised at how simple it is to use DevCon however I still dont understand why cant I detect when the serial port fails.
Excellent workaround though
(5,022 Views)
