display VI Hierarchy Window
Hi all,
How do i call/display VI Hierarchy Window programmatically>?
thank's.
Message 1 of 13
(5,131 Views)
Use the Application Method "Get Hierachy Image Scaled" and display it using Draw Flattend Image with a picture control.
Christian
Message 2 of 13
(5,117 Views)
I know it's not a good solution but here's one :
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
Message 3 of 13
(5,114 Views)
Hi Christian,
can you please send an example?
regard's
eyal.
Message 4 of 13
(5,102 Views)
Christian
Indeed, can you show how to use this method properly, I keep getting either nothing or a "not enough memory to complete this operation"...
Epictetus
Antoine Chalons
Message 5 of 13
(5,091 Views)
Yes I have tried it works for me without any problem. Am able to save the image to a file and read it and display that to a picture indicator.
Message 6 of 13
(5,089 Views)
not working for me...getting nothing.see the attachment.did i do somthing worng?
Message 7 of 13
(5,084 Views)
Yes in 2009 it is not working but the same works fine in LV 2011. Check the attachements
Message 8 of 13
(5,081 Views)
i have labview 2011 still not working.....? can u send the image of what u did?
Message 9 of 13
(5,077 Views)
I can't get the same code to work in LV 2010. Smiley Sad
Epictetus
Antoine Chalons
Message 10 of 13
(5,076 Views)
