Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
display multiple values from different sources ?
metallifredd
Member
04-13-2005
06:52 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I want to display values from different sources in one single indicator on the frontpanel.
the values comes from different stages in a testprogram.
First I want to display the value from source one
Then I want to display the values from source two
and so on...
I only want to use one frontpanel indicator since the different values are never to be shown at the same time.
a little help would be very appreciated .
regard Fredrik (beginner)
0
Kudos
Message
1
of 3
(2,910 Views)
Reply
Re: display multiple values from different sources ?
Knight of NI
04-13-2005
06:55 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Hello metallifred,
why not use a local? (right-click on indicator terminal, choose "create local").
0
Kudos
Message
2
of 3
(2,906 Views)
Reply
metallifredd
Member
Author
04-13-2005
07:10 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
ah that seems to work just fine.
thanks!
0
Kudos
Message
3
of 3
(2,902 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
