documentation error: Convert PID Gains
There's an error in the documentation for the Convert PID Gains VI. In the table explaining the calculations, for the Parallel form, the documentation says (Ki = Ki') but the actual calculation in the VI is Ki = dT * Ki' :
(4,131 Views)
nathand,
There's definitely a descrepancy between the table in the help documentation and the block diagram code that you posted. I'm working through determining the proper fields to file a documentation CAR, and I'll update you when I've actually got it filed with the CAR number.
Daniel V.
Applications Engineer
(4,079 Views)
Accepted by nathand
nathand,
I've filed CAR 595523 to address the conflicting equations.
Daniel V.
(4,074 Views)
