drawing multiple data on same graph
Hello everyone :
How I can plot multiple data on the same graph, for example I want to plot sin wave, cos wave and square wave on the same graph and marking each signal with special characteristics such as color or symbol ?
(3,251 Views)
What have you tried? Have you looked at the help and examples?
(3,232 Views)
Hello there,
Thanks for the reply.I found it is easy to merge  two plots in one graph using normal labview. but, I can't do this in labview NXG and I doesn't have any tutorial about this.
(3,146 Views)
Accepted by ASHLY19
Hi ASHLY19,
How are you doing this is in LabVIEW 2019? I would start there and try that in LabVIEW NXG.
There are a variety of ways but for a simple method to do this, you could use a Build Array in LabVIEW NXG. See below:
Frank
(3,120 Views)
