eg&g princeton applied research 273 potentiostat
I'm looking for a Labview GPIB driver for this instrument. Any suggestion will be appreciated.
Message 1 of 15
(9,254 Views)
Did you have any luck finding a driver for this potentiostat?
I also have a 273~A potentiostat I wish to control, any help would be appreciated.
Message 2 of 15
(9,181 Views)
Hey guys, if someone got any VIs, please I'm interested too,  keep touch here, i'll reply when my program will be done
Message 3 of 15
(9,117 Views)
I am still at a basic level. The only VI's I have are status and error questions and remote programming of front panel.
I am still trying to understand what some of the commands such as cv do. Since so far a command such as CV with a string of numbers also sends a number of other commands to the machinesuch as settings.
Any information you may have as to what other commands are sent along with this CV command would be appreciated.
e.g. what needs to be set before running CV command.
Message 4 of 15
(9,110 Views)
Your VIs should be helpfull for us, Can I?
Message 5 of 15
(9,108 Views)
sure, I am just trying to work out how to attach the programs, is this best done through email?
Message 6 of 15
(9,079 Views)
Sure but you may attach the file to this message here
Message 7 of 15
(9,077 Views)
um, I forgot about his until checking email
Message 8 of 15
(8,999 Views)
Hi m.m.h
I am trying to use your vi to control my EGG 273A.
When I open up the itview.vi, I get error messages saying two of the sub-vi's are
missing Z-axis Grapher and read_q_stepdata. I am fairly new to Labview -
and am not able to fix this myself.
Any help is appreciated.
Thanks.
Hovard
Message 9 of 15
(8,591 Views)
 Blundered across this exchange while searching for the info below
Try this link:
http://www.stolaf.edu/people/walters/pdf/polaro.pdf
Lab instructions for a homemade DME apparatus using Labview. Look halfway down the document.
Contains numerous vi's for controlling a homemade pstat.
Dangerous Bill
Message 10 of 15
(8,070 Views)
