eg&g princeton applied research 273 potentiostat
Hi, I am also trying to control a potentiostat using Labview.
But I don't know anything about Labview...are there any VIs I can take a look at?
Any help would be nice, thanks.
Message 11 of 15
(1,818 Views)
I would suggest looking at this example using it for electroysis
http://decibel.ni.com/content/docs/DOC-4097
Message 12 of 15
(1,814 Views)
I met the same problem.  Some VIs are missing.  Did you figure out how to fix it?
Message 13 of 15
(1,709 Views)
I am facing the same issue you had. Were you able to connect the 273 to LabVIEW ?
Message 14 of 15
(924 Views)
You will find more answers if you search this instrument with the acronym PAR 273.
I found the most useful answer in this link on the forums:
https://forums.ni.com/t5/Multifunction-DAQ/data-acquisition-via-GPIB-USB-HS-from-EG-amp-G-PAR-273/td...
Message 15 of 15
(885 Views)
