email using Labview
@Prashant S wrote:
Whenever any alarms generate, a email will be sent to concern person.
Prashant, you need to learn to search. This question has come up MANY times, and has been answered MANY times. If you have problems with specific solutions, then post what your specific issue is.
@ramses64 wrote:
Is the router's port 550 (SMTP) opened ?
 ???  25 is the default SMTP port.
@anurag267 wrote:
Hi guys I also tried to mail a small text messsage but came across with some error named ' SMTP:550 5.7.1 Unable to relay for '
How do I overcome this??
 You are trying to use an SMTP server that's in a different domain than the "From" address.
What carrier are you using?
The 'email address' you use will be the following, where XXXXXXXXXX will be your cell phone number (ex. 1234561234)
Verizon:
XXXXXXXXXX@vtext.com
Sprint:
XXXXXXXXXX@messaging.sprintpcs.com
AT&T:
XXXXXXXXXX@txt.att.net
Alltel:
XXXXXXXXXX@message.alltel.com
This is just a small list, but it will be similar for all carriers.
 Another ??? Where did you get the impression that the user was trying to call a cell phone? The OP asked how to send an email. While it's true that cell carries provide email addresses that can be used to send messages to phones, I certainly didn't read that from:
"Whenever any alarms generate, a email will be sent to concern person."
Message 11 of 15
(1,535 Views)
Verizon:
Sprint:
AT&T:
Alltel:
I think I misunderstood what he meant. I thought in addition to the email he wanted to send a text message, as in to a cell phone. My mistake.
Cory K
Message 12 of 15
(1,532 Views)
Hi
V-F
Message 13 of 15
(1,520 Views)
@ramses64 wrote:
Hi
Smercurio is actually very helpful in this forum. In fact he has over 10,000 posts helping people on the forums.
And he is not even paid to do so.
If he is criticizing someone's answer, he is probably right. In this case, I simply misunderstood because there is obviously a language barrier we are trying to overcome here. There is no need to get an attitude with people here.
Cory K
Message 14 of 15
(1,513 Views)
@ramses64 wrote:
Hi
Actually, 550 is a relay denied error, not the port number, so perhaps you should consider waking up and paying attention instead of being stupid by putting your foot in your mouth.
Message 15 of 15
(1,511 Views)
