erreur 33816
Bonjour,
je me trouve devant le problème suivant :
J'effectue une opération sur un module FP-PG-522.
J'obtiens une erreur 33816" caractère inattendu dans la réponse Optomux".
Quand j'effectue la même opération en demandant l'animation de l'exécution, je n'ai aucune erreur !
Quelq'un aurait une explication ou solution ?
Merci de votre aide
Message 1 of 9
(3,924 Views)
Hello Jacouille,
Posts in French should be placed on the French Forum:
http://forums.ni.com/t5/Discussions-au-sujet-de-NI/bd-p/4171
If you prefer to continue in English, then please repost the question (in English) below.
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 2 of 9
(3,896 Views)
I am faced with the following problem:
I perform an operation on an FP-PG-522 module.
I get an error 33816 "unexpected character in Optomux answer."
When I perform the same operation by asking the animation run, I have no error!
Quelq'un have an explanation or solution?
Thank you for your help
Message 3 of 9
(3,891 Views)
Hello Jacouille,
I don't directly see how this error is related to the FP-PG-522 (Pulse Generator) module.
It seem like this error is coming from the communication with your "Optomux device".
- What device are you communicating with?
- How are you communicating with this device?
  I expect you are using an application that implements the Optomux protocol on top of a serial port? (http://en.wikipedia.org/wiki/Optomux)
- Did the application work perfectly before?
  If yes, what changed since then?
Kind Regards,
Message 4 of 9
(3,887 Views)
I use an solid state relay to acting en electromagnetic pump.
I use a serial cable between the PC and the NI FP module (9600 bauds)
The only change is the PC
Many thanks
Message 5 of 9
(3,882 Views)
Can you share a MAX report of your System?
http://digital.ni.com/public.nsf/allkb/271F252B4EF0A2E0862570E70056A1E4?OpenDocument
Can you also show a screenshot of how is seen?
Thanks in advance!
Kind Regards,
Message 6 of 9
(3,880 Views)
in attachment the report,
Message 7 of 9
(3,851 Views)
Hi Jacouille,
Do you have the error also when only one "P0x" is TRUE at a time (for example P01= TRUE and P02, P03, P04 = FALSE)?
If no, can you try to "sequentialize" your four functions to see if it is better?
Also, can you look if the error is always coming from the same function out of the four?
Kind regards,
Cédric | NI Belgium
Message 8 of 9
(3,800 Views)
Accepted by Jacouille
it's seem that the problem comes from the PCIe card.
I put an old card on the PCI slot and the problem disapear.
Thanks for your help
Message 9 of 9
(3,764 Views)
