error-229771 and MAX database is not running
You have to reserve the chassis before you can use it. This forum talks about reserving chassis in programmatically:
https://forums.ni.com/t5/Multifunction-DAQ/How-do-I-Reserve-an-Ethernet-based-cDAQ-chassis-in-softwa...
Wan L
Applications Engineer
http://www.ni.com/support
Message 11 of 13
(615 Views)
Would you be able to provide and example of this used in a VI?
Message 12 of 13
(596 Views)
One of the posts in that thread mentions two shipping examples. They are no longer in newer versions of LabVIEW. However, they can be found here:
https://decibel.ni.com/content/groups/ni-daqmx-examples
Wan L
Message 13 of 13
(583 Views)
