event key down
I have a question regarding the event structure.
If you make an event for 'key down', where can you specify which key is being pressed,
instead of any key
Cory K
(3,526 Views)
Accepted by Cory_K
It catches all keys.  But there are nodes on the left side of the event structure for char or scan code. These tell you which key is pressed.  You can compare it to your character or scancode of interest and if they match, execute the code in a case structure.
(3,514 Views)
Good idea, I'll give that a shot
Cory K
(3,509 Views)
And if you use the "key down ?" event, you may even filter the event and decide to discard it, or to change the key pressed value associated with it before passing it to the VI.
This should also work with Mods keys, for intance to simulate a capsLock on, but I have never been able to work it out 😞
Chilly Charly    (aka CC)
(3,488 Views)
