excel 2000 labview 7 windows 98
I'm finding troubles with excel 2000 when I use open excel.vi. When the application runs on Windows 2000/XP machine all seem to be rigth, but with Win 98 OS the message "...page error caused in rpcrt4.dll.." appears and the program aborts.
Have you any suggestions?
Thank you for your care.
Chyrus
(2,853 Views)
did you try re-link the Excel application reference in the "open excel.vi"?
-Joe
(2,853 Views)
Dear Joe,
the application reference was linked. I tried to relink but nothing changed.
The application abort and excel does not work.
The following message appears in message box :
"Application ha provocato un errore di pagina non valida nel
modulo RPCRT4.DLL in 0167:7fbd0894.
Registri:
EAX=01e63c73 CS=0167 EIP=7fbd0894 EFLGS=00010216
EBX=01e5fb38 SS=016f ESP=01e5f958 EBP=01e5fb48
ECX=7710ee58 DS=016f ESI=00000484 FS=19cf
EDX=bff76855 ES=016f EDI=7710ef6e GS=0000
Byte all'indirizzo CS:EIP:
ff 30 ff 75 d4 8d 85 1c fe ff ff 50 e8 cb 0b 00
Immagine dello stack:
01e5fe9c 00000000 00000000 01e5faa0 80000001 00000000 00000000 006f0072 00000000 00740053 00620075 00000001 00000000 00000000 00000032 00000000"
Does it suggests something?
Thanks 4 your care.
Chyrus
(2,853 Views)
could you translate the message into english? it's hard to figure it out myself. My suggestion would be search the msdn site for the particular error code returned by excel. It seems like you also have the labview abort problem. Well, in this case re-install excle or labview or both might help.
-Joe
(2,853 Views)
