exe crashes with no error even though the VI works fine
@jgvarner57 wrote:
 It turns out setting the VI to hidden isn't available when the VI is active, ...
Do you care to expand on that statement?
This seems to work just fine.
Former Certified LabVIEW Developer (CLD)
Message 11 of 12
(594 Views)
Interesting. I didn't think you should FP.Open a VI that is already currently open, but that does also seem to work. That is another alternative to simply setting the window transparency.
More importantly, I tested the application after making these changes in all the places where I was closing Front Panels, and now the exe works perfectly! That was the problem.
Message 12 of 12
(588 Views)
