exe settings history
Hi All,
My assignment (pre-employment test) is to duplicate the operation of Convert for Windows in LabVIEW.  The Convert for Windows .exe opens with the Listbox settings of the previous execution (there is NO .ini).  It is my understanding that EXEs can be configured to "remember" selected settings.
However, after many variously worded searches of the LabVIEW Forum, any related response says "not possible".
So, how do I build my EXE without an ini so it will remember my history cluster that contains category and in/out units Listbox settings?
And, if "not possible", why does Convert for Windows "seem" to "remember"?
ThanX Much.
1LMR
Message 1 of 23
(4,165 Views)
Using registry settings instead?
Message 2 of 23
(4,163 Views)
I understand that you don't want a separate ini file.  You can actually compiled the ini file into your exe, so that it is just one exe, and the ini is out of sight.
Kudos and Accepted as Solution are welcome!
Message 3 of 23
(4,155 Views)
what do you  mean by using registry setting?  Can you give me a simple example?
Message 4 of 23
(4,158 Views)
I mean writing to and reading from Windows registry using the Windows Registry Access VIs.
There are examples shipped with LabVIEW.
Message 5 of 23
(4,150 Views)
jyang72211,
Great!
ThanX.
I should have thought of trying to do that.
1LMR
Message 6 of 23
(4,142 Views)
All the tools you need are here:
(Look at the help. There are even shipping examples)
Message 7 of 23
(4,147 Views)
sebster,
Thank you for the additional information.  Your original "Using registry settings instead?" response turned my brain to mush, again.
ThanX Much!
1LMR
Message 8 of 23
(4,139 Views)
Message 9 of 23
(4,139 Views)
Sorry, I was suggesting possible reasons for the "how do I build my EXE without an ini..." and "why does Convert for Windows "seem" to "remember"?" questions.
Message 10 of 23
(4,133 Views)
