exisiting TCP data
I am putting together a VI to read TCP data that has a 12 byte TCP wrap (the first 12 bytes of every TCP packet of data) but I am having problems when TCP data does not exist.
Is there a way to determine if TCP data exists for a specific device (IP address) before I attempt to read the
TCP wrap that is used for each TCP packet?
thanks
Message 1 of 10
(4,859 Views)
No not really - set a suitable timeout value and ignore the timeout error (code 56) if no data comes in.
(blog)
Message 2 of 10
(4,857 Views)
Thanks for the reply.
How do I ignore the time out error?
Message 3 of 10
(4,851 Views)
Consult the excellent error handling chart I have attached!
(blog)
Message 4 of 10
(4,845 Views)
I have found what is causing the error.....
There sems to be a couple different variants of one field of TCP data that can either be 32 or 34 bytes of data
where if I do not read the correct number of bytes I end up with a framing error in my decoding...
This first byte where I am reading 1 byte in the picture below contains the number of bytes that needs to be read.
I would like to accomodate for reading the correct number of bytes and have tried unsuccessfully with the following:
Any suggestions on how best to do this?
thanks again
Message 5 of 10
(4,816 Views)
I'm pretty sure you want to stick an array index in there as the U8 out is a numeric array and you want the Zero index.
Message 6 of 10
(4,805 Views)
What is the format the byte you read for the length? Type Cast to a numeric may be what you need.
Lynn
Message 7 of 10
(4,797 Views)
Thanks for the replies...
My bad, I meant to type cast instead of the array to u8 ...
Message 8 of 10
(4,762 Views)
Maybe I spoke too soon...
The value that seems to change is the first byte of the TCP data which contains the size of the TCP data in bytes.
In what I am seeing, this first byte is 20h (0x20) when looking at the TCP data in wireshark, and when my front panel
displays this value as the indicator "String"  (with hexidecimal display style), it is shown as "18" and in probe watch [4} "|"
What I am trying to do is read this first byte, and then use it to read the remainder of bytes in that TCP packet but I obviously don't know what I am doing or how to do that.
Any help with this is greatly appreciated.
Message 9 of 10
(4,754 Views)
Accepted by topic author LV-rookie
0x20 is 0d32 - which is the number of bytes in your packet. If you type cast your 1-byte length string to a U8, you should get the packet size.
(blog)
Message 10 of 10
(4,741 Views)
