extracting an array of one cluster element from an array of clusters
Is there an easier way?  Thanks!
Bill
CLD
(Mid-Level minion.)
Message 1 of 8
(6,851 Views)
Accepted by billko
No
Message 2 of 8
(6,846 Views)
Not even a "Reply hazy try again", huh?  😄
Bill
CLD
(Mid-Level minion.)
Message 3 of 8
(6,840 Views)
With 2017's type parsing palette it is theoretically possible to get array data and check that it has a type of "Cluster".  And script out the vi's that get arrays of each single element.  I wouldn't call that "Easier"
Message 4 of 8
(6,822 Views)
You might be interested in this idea: Why is there no function to reverse "Index & Bundle Cluster Array
Message 5 of 8
(6,780 Views)
That is pretty much exactly what I was asking about.
Bill
CLD
(Mid-Level minion.)
Message 6 of 8
(6,761 Views)
Or using a VIM (2017) this would be possible, but you'd probably have to make a new VIM for each index in the cluster to pull out.  Like a "Get Element 1 in Cluster.vim" "Get Element 2 in Cluster.vim" and then that would work changing the outputs based on the cluster type wired.
Also as mentioned in the idea exchange there is an XNode that does this over on LAVA.
Message 7 of 8
(6,716 Views)
Hang tight.  I may have missed a "outlook hazy try again later" response.  But I stand by the NO for now.
Message 8 of 8
(6,690 Views)
