failed to initialize Trace32
Where to download TRACE32 virtual instruments library?
Message 11 of 13
(1,061 Views)
Refer to Page 4 in this doc - https://www2.lauterbach.com/pdf/int_labview.pdf.
Follow these steps to install the VIs for TRACE32 and configure TRACE32:
1. Close TRACE32.
2. Close LabVIEW.
3. In the TRACE32 installation directory, browse to the subdirectory demo\env\labview.
Unpack the contents of the virtual_instruments_for_trace32_labview.zip file to the directory with user library files in your LabVIEW installation. The user library files are located in the following directory: C:\Program Files\National Instruments\LabVIEW\user.lib\. Localization of the user.lib directory can be different, depending on the LabVIEW installation directory.
4. Start LabVIEW.
5. Open the new blank VI file and select the Window -> Show Block Diagram from menu.
Click the right mouse button to see the functions palette and select User Libraries and Virtual Instruments for TRACE32.
Now, all Virtual Instruments for TRACE32 are available in LabView.
- Partha ( CLD until Oct 2027 🙂 )
Message 12 of 13
(984 Views)
would you like to share the link to download trace32 lib
Message 13 of 13
(965 Views)
