Hi Lynn ,
I'll attach the VI again , but i suspect you'll find the subVIs missing if you open the VI without the speedy 33 target type. But i do understand your explanation of the nyquist theory . its interesting , becasue i have not generated a signal, but i am only using bits (binary bits ) to check the fft and ifft results . Anyway, your explanation gets me to this question . do the fft and ifft blocks only apply to a signal form ? . but i expect it should not make a difference even if i feed in a array of bits to the fft and ifft block .. please do let me know if i am mistaken
Mano ..
