file sharing violation with Ni OPC Server
Hello to all,
I no experience with this particular program and need assistance.  I encountered an error while accessing the  NI OPC server program, the error is as follows: "unable to open project file: A sharing violation occurred while accessing C:\Program Files\APPLET\etc..."  I also found this eror message, see attached, that I believe is related.  I realize that is not much to go on but any assistance on troubleshooting this would be great.  Thanks.
Amstedrail
(2,454 Views)
Hello Amstedrail,
I see on the screenshot you provided that you have a Citadel Event ID 5123 error. As this other forum thread shows, this might be an error with Citadel not having permissions to write to a database folder. This is in case you are using LabVIEW DSC.
Daniel REDS
RF Systems Engineer
Help us grow.
If a post solves your question, mark it as The Solution.
If a post helps, give Kudos to it.
(2,319 Views)
