09-01-2008 05:23 AM
Hi all,
I am using a digital graph and I want to differentiate 1 and 0 with colors. ie 1(HIGH ) region should be filled with one color and 0(LOW) should be filled with another color. Is it possible to do in that way or any other graph/chart that support my requirements ?
I have attached a image picture of my requirement.
Thanks in advance.
Raja
09-01-2008 05:42 AM
Hi Rajaa,
I hope your well.
I have done an example in LV8.5.
But basically, i've used a digital data input, used a convert to boolean array and then changed the LEDs in the indictor array to square, and with an off colour of red.
Let me know what you think.
09-01-2008 05:57 AM
Hi Hillman,
Thank you for your reply. Could you post that in 8.2
Raja
09-01-2008 06:08 AM
hi
sure thing!!
09-02-2008 10:24 AM
You may also be interested in this post if you wish to have the bits colored on the graph itself. Though if you are not using LabVIEW 8.5 or above, some of the property nodes being used are not available.
