find dlls used in sub Vis
Hi All,
Is there a way to locate all dynamically loaded files in a VI and all of it's sub-VIs?  I am trying to build an exe, and I seem to be missing a dll that it needs, but I can't find the call.
Jim
Jim
LV 2020
(3,221 Views)
If you haven't changed the labels a text search for "Call Library Function Node" should find you all the external dll calls.
André
André (CLA, CLED)
(3,214 Views)
I dont think so, without a proper documentation, atleast inside the Main/Top-level VI's diagram itself. Smiley Sad
Unless n until it is written in some known place, for example, the calling VI, it is pretty much difficult to trace all those stated stuff. Smiley Wink
- Partha ( CLD until Oct 2027 🙂 )
(3,211 Views)
Thanks Andre,
six years of this and still learning!  I've never even thought to try a text search.
Jim
Jim
LV 2020
(3,209 Views)
Jim,
I didnt negate Andre's reply, though...
BTW, did you manage to find all the dynamically loadable VIs ? Because, they wont be shown in the VI Hierarchy. Smiley Wink
(3,204 Views)
Partha,
Yes, there weren't actually any dynamically loaded VIs, and actually the other thread helped me remember that I was forgetting to add lvanlys.dll when building the application.  The text search turned it up as well.
Jim
Jim
LV 2020
(3,198 Views)
