format and append data to word file
As per your expert guidance, I wired through the tunnel and introduced shift registers as well. Still Getting the same output. Kindly forgive me and help. Thank you in advance. Attaching the vi here.
Message 11 of 15
(1,446 Views)
Accepted by salauddin
Hi salauddin,
@salauddin wrote:
Still Getting the same output. … Attaching the vi here.
Ok, looks better now.
As using correct shift registers to forward the RGT class/object as it should seems not to improve the table formatting you should implement my other suggestion: collect your table data on your own (in a shift register or a conditional output tunnel) and write the table just once after your loop:
Message 12 of 15
(1,421 Views)
Dear GerdW, Thank you for your humble help. I seek clarity regarding 2 things which I have depicted with a red boxes in the below picture.
I am trying to recreate the same code as above but having issues with wiring. May i know how that selector functionality in the 1st box above is achieved and what does the red x mark on the below vi indicate? Below is the picture of me trying to recreate
Message 13 of 15
(1,400 Views)
Hi salauddin,
I used a conditional tunnel: use the context menu (aka right-click menu) of the tunnel to changes its mode.
The "red X" indicates a deprecated function as I use a more recent LabVIEW version than you do, no need to worry about…
Message 14 of 15
(1,392 Views)
Thank you, GerdW. I am able to wire now.
Message 15 of 15
(1,372 Views)
