fpga I/O viewer
Hello everyone,
Is there some kind of tool where you can see which state each IO pin of the FPGA (mine is PXI-7842R) has? If not, can anybody tell me how I can monitor the status of the FPGA IO pins?
I have a large program that changes the output lines at different places (I know, bad programming, but its a test program) so it is hard to keep track in which state all the outputs are. Some kind of tool for this could be very useful.
I'm not sure if just reading the signals with a I/O node in a seperate loop will work because these pins should be set as Digial Out only.
Dries
(2,396 Views)
Hello Dries,
I think this is the tool you're looking for:
https://decibel.ni.com/content/docs/DOC-5560
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(2,366 Views)
