02-20-2012 04:55 AM
Hello everyone,
Is there some kind of tool where you can see which state each IO pin of the FPGA (mine is PXI-7842R) has? If not, can anybody tell me how I can monitor the status of the FPGA IO pins?
I have a large program that changes the output lines at different places (I know, bad programming, but its a test program) so it is hard to keep track in which state all the outputs are. Some kind of tool for this could be very useful.
I'm not sure if just reading the signals with a I/O node in a seperate loop will work because these pins should be set as Digial Out only.
Dries
02-27-2012 09:00 AM - edited 02-27-2012 09:03 AM
Hello Dries,
I think this is the tool you're looking for:
https://decibel.ni.com/content/docs/DOC-5560
