fpga compilation error_LV 2010SP1, Win7, Xilinx 10.1
Hello
are there any other things that i should look it? i also got the LabVIEW license activated sometime back.. still the same issue continues..
I called local NI support and they have suggested i look at the forum posts and try the things out.. i told them i had already tried which ever i could, after looking at the forums..
so, they asked for time to get back to me..
Regards
Freelance_LV
TestAutomation Consultant
Message 11 of 16
(737 Views)
Have you tried repairing FPGA drivers??
If not try that and check.
Message 12 of 16
(734 Views)
the problem is, since we do not have admin rights, i have to call up the IT guys for all this stuff... and they come almost half a day after we raise an SOS..
so, i will try to get them reinstall it...
but what i wonder is, how was i able to compile a cRIO FPGA code and acqurie data and not able to compile a PXI FPGA code?
Regards
Freelance_LV
Message 13 of 16
(731 Views)
Its a good question.
To ensure that there is no problem with the driver just built a cRIO FPGA vi and compile it. If the error repeats then we can try repairing or reinstalling the drivers.
Message 14 of 16
(728 Views)
i said, i was able to compile a cRIO FPGA vi. but am not able to compile a PXI FPGA.. the first thing i did was to connect a cRIO and test. it was successful..
Regards
Freelance_LV
Message 15 of 16
(723 Views)
For an update:
I have repaired the FPGA drivers yesterday afternoon and restarted the PC. I came back this morning and found that the PXI Chassis is not detected in the MAX anymore!
i cannot see the chassis and therefore the AI/AO/FPGA cards inside the chassis.
so.... leaving the ENTIRE NI software for uninstallation over the weekend.
hope the next week turns out to be good...
Regards
Freelance_LV
Message 16 of 16
(706 Views)
