fpga compile error
I am converting a piece of code from 8.5 to 2011.  When I tried to compile the fpga vi to a bit file, I get the attached error.  Why is that?  thanks!
Kudos and Accepted as Solution are welcome!
Message 1 of 9
(3,741 Views)
Have you allready installed the LabVIEW 2011 FPGA Module f1 patch?
Christian
Message 2 of 9
(3,727 Views)
the version conversion board may be able to help
http://forums.ni.com/t5/Version-Conversion/bd-p/VersionConversion
Please remember to accept any solutions and give kudos, Thanks
LV 8.6.1, LV2010,LV2011SP1, FPGA, Win7
Message 3 of 9
(3,725 Views)
Definitely not!
Christian
Message 4 of 9
(3,719 Views)
I tried to install it, but it won't let me.  I think I have the patch already.
Message 5 of 9
(3,716 Views)
Accepted by topic author jyang72211
The thing is that the only solutions I found regarding this error are either to install the patch or repair/re-install the Xilinx Tools or LabVIEW FPGA.
Christian
Message 6 of 9
(3,709 Views)
I am gonig to repair the LabVIEW FPGA.  How do you re-install the Xilinx tool?  Isn't that part of LabVIEW FPGA?
Message 7 of 9
(3,706 Views)
That's right, they are part of LV FPGA. However they are listed separately under the Add/Remove Programms in Windows Control Panel.
Christian
Message 8 of 9
(3,703 Views)
Uninstalling and installing all the software solved the program.  I have his type of problem will not occur too often.  I do not want to uninstall and reinstall the program again and again.  Thanks!
Message 9 of 9
(3,689 Views)
