06-13-2006 11:12 AM
engt Hello.
One of the engineers in our R&D department was able to replicate the problem you are seeing by changing his regional settings on his computer to Turkish.
Right now, the only way to get over this error will be to transition to an English version of the Operating System as we do not test the module on all languages.
Please post and let us know if this helps.
Efosa O.
NI-AE
06-13-2006 11:23 AM
01-17-2007 08:44 AM - edited 01-17-2007 08:44 AM
Hi
I have the same problem!!! Except that I'm running Windows 2000!! ANd this error has appared since i'm under LV 8.2.
I've tryed to change regional to english it doesn't work.. 😞 I will try to put it in englisk (usa) to see.....
here is the error message :
Mapping design into LUTs...
ERROR:MapLib:661 - LUT4 symbol "mytop/n_413/n_320/n_314/n_311/_n0002<0>1"
(output signal=mytop/n_413/N32) has input signal
"mytop/n_413/n_320/n_314/n_306/xeqy<0>" which will be trimmed. See the trim
report for details about why the input signal will become undriven.
ERROR:MapLib:661 - LUT4 symbol "mytop/n_413/n_320/n_314/n_311/_n0002<1>1"
(output signal=mytop/n_413/N30) has input signal
Error found in mapping process, exiting...
Errors found during the mapping phase. Please see map report file for more
details. Output files will not be written.
Design Summary
Number of errors : 2
Number of warnings : 11
ERROR:Xflow - Program map returned error code 2. Aborting flow execution...
Message Edité par julesjay le 01-17-2007 08:46 AM
