03-11-2010 09:10 PM
Hi All,
I think I'm doing some silly mistake somewhere..just not able to figure it out...
Ok here's my signal from DAQ (3 channels) For each channel I want to extract only a portion of it (approx 4000 samples around the peak of the signal- Attached is a lvm data file)
I've attache dthe vi I'm trying to get a simple subset of 4000 samples...the output seems to get only one single point...
please help....
03-11-2010 09:43 PM
sorry for a trivial question..the waveform din't get the dt so it was plotting all points on a single point...Now i'm giving the dt and its working fine..
thanks for the forum..atleast I know there r others who can help me..
11-16-2011 07:12 AM
hi,
I am facing a problem with the 'get waveform subset' vi. As I tried to run the programm error occured saying something like the start value too large and the duration input is not an integer multiple of dt.
Do you have any idea how to fix it?
Thank you.
