getting .vis from .dll ????
Yes, kaem is right, it works in both cases!
And regarding the extentions it works without problems before 8.x, but since 8.x you have to change settings of the project (VIServer enable). If this also doesn't work you have to add the SubVIs as dynamic VIs. Then it should be possible.
BR, Christian
Message 11 of 11
(267 Views)
